Can I flip the direction of the vector arrows that show deviation on Position?
I am doing some simple position measurement on some holes on a die cast part. However, when I click to show vectors, they point in the direction towards where the hole should be and not in the direction of the direction the hole is moving from nominal? Is there a way to change this? All of our CMM report outs, that everyone is used to seeing, shows the arrows in the direction of movement, not direction towards nominal.
Following this topic too. Vectors is a great feature but is not intuitive when the direction is pointing from actual to nominal.
Hi,
unfortunately there is no possibility to change the current direction, but I added your wish to our internal ticket. I can't promise if or when we would implement a solution to this wish.
Regards,
Bernd
Edited
  • 4 months later...
Good morning Bernd. Has there been any update for this request? Is there a plan to implement this?
We cannot confirm that we plan to implement this for a given version, but we are aware of this topic and that it is important to many customers.
