Minimum thickness location vs reference
Hi,
I'm trying to find the location (height and angle versus reference point) of the thinnest point in a sample.
Any idea how to do this?
Using GOM Inspect Professional version 2019.
Thank you!
Hello Florian,
thinnest like in material thickness? You can create a material thickness over the area of interest and then place a minimum label. It is possible to construct a point on a minimum label, which can be used for checks or distance checks.
Nanno
Hey Nanno,
Yes, material thickness.
Is there an option to have the software place that minimum label automatically, rather than manually searching for the thinnest point?
I'll have to measure a significant number of samples with a material distribution that will vary a lot sample to sample. The thinnest point will be in random locations.
Florian
