Need Help When Importing a mesh file.
I have my GOM Inspect file ready with all the dimensions I want to inspect. I am using a temporary mesh in the GOM Inspect file, and I have created my g3d Mesh file at a later time. When I go to drag the mesh file into the GOM Inspect file everything looks normal and the mesh is aligned onto the 3d model but my actual values from the g3d file are not auto populating like they use to, any help would be appreciated.
Hi,
sounds strange. I recommend to contact your local ZEISS partner and to supply the project for a deeper investigation why there is no update in your concrete project. The reasons could be quite different: I guess the parametric could be broken, but this is only a guess.
Regards,
Bernd
