[La...] Posted March 22, 2024 Share Posted March 22, 2024 Hello, I'm using GOM Correlate Pro 2022 and encountered an issue when importing a data file as Value Elements. My data file is acceleration measured in g's, and I specify: Physical Quantity: Acceleration Unit: g Once imported, I create Data.DIM and it shows it's inspecting "against fixed value: 0 kg". So at some point the acceleration g's is misinterpreted as grams. I'm able to repair this by modifying the creation parameters of the Value Elements item, but hopefully this bug can be fixed in a future release. Thanks! Link to comment Share on other sites More sharing options...
[Da...] Posted March 22, 2024 Share Posted March 22, 2024 Hello Lauren, thank you for your feedack. This is indeed a bug in our Software. I will take care about that. Regards, Daniel Schrein Link to comment Share on other sites More sharing options...
