polygonize in the background
It is possible to polygonize in the background in order to always have the sensor active  to avoid
disconnection to the scanner and keep using it for new acquirement
Hi,
the software will deinitialize the sensor when you start polygonizing. You can simply start a new software instance and start measuring, while the other instance is polygonizing.
Nanno
