Compare two Aramis measurements
It is possible to compare FEA results with an Aramis measurement.
But is it also possible to compare two Aramis measurements with each other?  (on difference in major strain for instance)
If yes, what is the process
  • 4 months later...
Hi Romke,
it is Possible to compare between the FEA results with an Aramis measurement through surface check computation .
 Here is a Link for the pptx file for explanationLibrary (zeiss.com)
Also a webinar for the Steps : Library (zeiss.com)
But a Comparison between the two Aramis measurements as the calculation of the Project works only for one component.
Mohamed
