Custom Variables in PiWeb
Hi at all!
When I create a custom variable in piweb designer, it creates it as a "string" and therefore I can't use it to do mathematical calculations. Is there a way to turn it into a number?
Thank you!
  • 2 weeks later...
Hello
are you using a text input field in your report to set the custom variable? Then in its properties choose "Format" -> "Number fomatting"
