[Fe...] Posted April 30 Share Posted April 30 Hi at all! When I create a custom variable in piweb designer, it creates it as a "string" and therefore I can't use it to do mathematical calculations. Is there a way to turn it into a number? Thank you! Link to comment Share on other sites More sharing options...
[Sp...] Posted May 13 Share Posted May 13 Hello are you using a text input field in your report to set the custom variable? Then in its properties choose "Format" -> "Number fomatting" Link to comment Share on other sites More sharing options...
