Cant install ZEISS inspect
Hello,
I installed the Zeiss quality suite, logged in i go in the application menu but everything is continuing loading. I cant install any application. Do someone got the problem ? Have an idea for solution ?
I tried on 2 computer i got the same problem.
Hello,
If you not already have registered to the Software Store in ZEISS Quality Suite please try to (e.g. to get a Trial), after this you can again try install ZEISS INSPECT.
Another possibility is to go to ZEISS Portal and use the Installer that can be downloaded there.
  • 3 weeks later...
Restarting my PC, logging in multiple times, and installing Windows software updates has helped me get things working in the past. But in general, Zeiss Quality Suite is just really buggy, and you will have to jump hurdles to get it working somewhat correctly.
  • 10 months later...
Derrien,
I would check to make sure your IT AV/Fire wall is not blocking the software from installing.
