script to generate coordinate system
good morning,
i am trying now with gom scripting and i am very new with this.
my goal is to make a script that generates a coordinate system for each circle I select in the tree.
The only thing I get with the recorder is to do the actions I need, but only for a circle called ‘1’.
I would like to make a multiselection ( manually), with it make a list and go taking all the circles of that list and make the actions that I share with you.
I have the logic of the script in my head but I am not able to do it.
Could someone help me?
sistemas.py
Hello Jon,
we have an article for selections here:
https://zeissiqs.github.io/zeiss-inspect-addon-api/2023/howtos/python_api_introduction/selecting_elements.html
It's from the Add-On development documentation you can find under "links" at the top of the page.
The code could look something like this and will create a list you can iterate through (a free python course is available in the training center, which is also linked at the top).
import gom
points = []
for e in gom.ElementSelection ({'category': ['key', 'elements']}):
	if e.get('is_selected')==True:
		points.append (e)
print (points)
For this application, a creation sequence on similar elements, you could also use a user defined inspection principle.
https://techguide.zeiss.com/en/zeiss-inspect-2023/article/cmd_inspection_create_user_defined_inspection_principle.html
 (measuring principles might differ and I used a "normal" position check, not GD&T but that works too)
Nanno
