[Ma...] Posted June 7 Share Posted June 7 Is there any way to change the max speed of the robot or the rotating table? I've tried to look through the inspect software but keep coming up with nothing. Thanks for any help. Link to comment Share on other sites More sharing options...
[Ja...] Posted June 10 Share Posted June 10 Hi, no, that is currently not possible in ZEISS Inspect. Paths that are "not validated" are moved slower than already validated paths, but aside from that there is no configuration option for the speed. What do you want to achieve? Regards, Jan Link to comment Share on other sites More sharing options...
[Ma...] Posted June 11 Author Share Posted June 11 Thats a disappointing to hear. Was looking to change the speed of the turn table to prevent the possibility of the object in the jig from moving due to higher accelerations after the path is validated. I guess I'll just make a better jig haha. Thanks for the info. Link to comment Share on other sites More sharing options...
[Ja...] Posted June 13 Share Posted June 13 Hi Matthew , i was also going to ask this exact question as to why you wanted this. As you say the best option is more robust fixturing. If it really is an issue that you cant solve that wasy your zeiss partner does have the possibility to tweak the speeds in the vmr , but this gets tricky to manage which vmr you use for what . Link to comment Share on other sites More sharing options...
[Th...] Posted December 11 Share Posted December 11 SLOWING DOWN YOUR TABLE.pdf Here's how to slow your table down. Link to comment Share on other sites More sharing options...
[Th...] Posted December 11 Share Posted December 11 Hope it helps. Link to comment Share on other sites More sharing options...
