[Ma...] Posted June 13, 2024 Share Posted June 13, 2024 Hello there, I have just started my adventure with DIC. I prefer to learn how to use it before my company will buy Aramis. That is why I was trying to measure sample deformation with my own Nikon d3100. I can see the speckle patern quite well but it is nearly impossible to define speckle for the software "Correlate 2019". What am I doing wrong? What kind of possible solutions can I implement to overcome my difficulties? Looking forward for your reply. Link to comment https://qualityforum.zeiss.com/topic/4047-picture-quality/ Share on other sites More sharing options...
[Ja...] Posted June 13, 2024 Share Posted June 13, 2024 Firstly the images look incredibly washed out so there is likely no chance to see contrast differences . Flash use , aperture , focal length needs to be fixed. Secondly from what i can see the speckle pattern is going to be very small from that far away Thirdly with a single camera you can olnly capture things in 2d , and you are not square to the samples by the looks of it so this will not help. Link to comment https://qualityforum.zeiss.com/topic/4047-picture-quality/#findComment-11739 Share on other sites More sharing options...
[Ma...] Posted June 14, 2024 Author Share Posted June 14, 2024 Thank you for your answer Link to comment https://qualityforum.zeiss.com/topic/4047-picture-quality/#findComment-11757 Share on other sites More sharing options...
[Th...] Posted September 20, 2024 Share Posted September 20, 2024 Hi Marcin, as James already mentioned: the images look very dark, blurry and you capture a 3D-scene which is not suited for single camera DIC. If you want to get into to 2D DIC at least make sure that you have a god signal (thus pattern) and a good signal to noise ratio (good lighting conditions)! This is an quite ok-ish example for contrast conditions (signal to noise ratio: ok. Pattern is not too good, as its quite regular): And this is an example for facet-sizes related to the pattern: Link to comment https://qualityforum.zeiss.com/topic/4047-picture-quality/#findComment-12578 Share on other sites More sharing options...
