[Ir...] Posted July 10 Share Posted July 10 Hello, Is there any way to get the list of inspection items related to a particular geometry to use in scripts. I have already found the code that allows me to get the list of those inspections that are out of tolerance: Changing the code a bit I printed the inspection items out of tolerance of cylinder C. However, cylinder C has more inspection elements that fall within tolerances. I need a line of code that allows me to get the entire list of C inspection items regardless of whether or not fall within tolerance. Link to comment Share on other sites More sharing options...
[Na...] Posted July 10 Share Posted July 10 Hello Irune, please have a look at the Add-on documentation here: https://zeissiqs.github.io/zeiss-inspect-addon-api/2023/howtos/python_api_introduction/selecting_elements.html#more-element-selection-options 'element' would be cylinder C in your case. Nanno Link to comment Share on other sites More sharing options...
[Ir...] Posted July 11 Author Share Posted July 11 Thank you, it has been very helpful! Link to comment Share on other sites More sharing options...
