Problems with the sensor
Hello,
I have a problem with my Atos triple scan II. For the last week I have been getting this error. Then I can't run GOM inspect and I have to restart the computer. Has anyone encountered this?
Hello,
with Hardware problems please contact your local support, ideally with a "gomsic" file (Help -> system analysis -> support data).
Nanno
Its been a while but this is most likely one of , or a combination of the following : sensor cable , internal network card in sensor or framegrabber network card in pc.  If you have a manual system you can test with a normal cat 5 cable to pc to eliminate sensor cable.  Obviously the other two things need assistance and spares from local support team to diagnose. This might get tricky as this hardware is now retired but hope you get sorted
