Keyboard Shortcuts
Are there any lists of current keyboard shortcuts, as well as a way to implement your own keyboard shortcuts? I have several processes that could be streamlined with a few keyboard stokes.
Example - when interacting with nominal element, a simple press of the "a" key would show the correlating actual element instead of going thru i-inspect wheel or long mouse drag to "relates to"
Thank you all very much!
Hello Chris,
there is a list of useful shortcuts here:
https://techguide.zeiss.com/en/zeiss-inspect-2023/article/general_useful_shortcuts.html
and you can define your own shortcuts by simply recording the command:
https://techguide.zeiss.com/en/zeiss-inspect-2023/article/cmd_sys_edit_shortcuts.html
I'm not aware of a function to show the correlating actual element though - but you can assign shortcuts to a script, which does this action. If you describe the application behind this, we can create a wish.
For other processes, like element creation sequences you might want to have a look at user defined inspection principles:
https://techguide.zeiss.com/en/zeiss-inspect-2023/article/cmd_inspection_create_user_defined_inspection_principle.html
Nanno
