[Ja...] Posted July 23 Share Posted July 23 I am trying to add a plausibility check to a touch sphere. the problem is the sphere is taking a reading from 3 contact points and the points taken are on the edge of the mesh (usually this would fail a plausibility check where the points manually created however this isn't an option. As a sanity check for this I wanted to add a check to the actual section, if this is compete at the point the sphere contacts the CAD the reading is good and when broken, this would give a bad reading. Is there a way to get the software to check for this incomplete actual section? Closest thing i can think of is a series of touch edge points that look to fail the plausibility checks. The attachment should clarify the issue a little. Any help would be appreciated. Good part.docx Link to comment Share on other sites More sharing options...
[Na...] Posted August 8 Share Posted August 8 Hello James, in 2023 there is an option "only touch from outside" for touch spheres - maybe this works as a check in your application. If you want use the section for this, there is a keyword "scanline_point_connection" which is either 'interrupted' or 'connected' for each point of the section. You could count the interruptions for example. It's also available in scripting. Nanno Link to comment Share on other sites More sharing options...
