Max Distance between two Curves
I know 2 CURVE DISTANCE give you a min distance between two curves. Is there a possibility to get the max distance between curves?
Hi,
as far as I know the maximum distance does not exist because it is not easy to specify which is the maximum distance.
But may be the following workaround is something you intended?
  • Create a 'Continuous curve distance' element
  • Check this element with a distance check (this also supplies a curve check element)
  • Select all points of the curve check element and create a _Maximum deviation picker_
Is this what you intented?!
Regards,
Bernd
