Display distance same as Autocad preview
Now i'm using Zeiss inspect 2023, and i want to show the distance value same as Autocad 2d drawing (Same as attach) to comparation the value between drawing and product.
Assuming this is measuring to a flat surface as I can not tell what the base is referencing. I would create a mid plane between the two long faces, create a plane on the end face, do an intersection line between each of those planes, create a point from a line, and then do a point projection distance from the reference base.
