[SR...] Posted August 2, 2024 Share Posted August 2, 2024 Now i'm using Zeiss inspect 2023, and i want to show the distance value same as Autocad 2d drawing (Same as attach) to comparation the value between drawing and product. Link to comment https://qualityforum.zeiss.com/topic/4166-display-distance-same-as-autocad-preview/ Share on other sites More sharing options...
[Au...] Posted August 2, 2024 Share Posted August 2, 2024 Assuming this is measuring to a flat surface as I can not tell what the base is referencing. I would create a mid plane between the two long faces, create a plane on the end face, do an intersection line between each of those planes, create a point from a line, and then do a point projection distance from the reference base. Link to comment https://qualityforum.zeiss.com/topic/4166-display-distance-same-as-autocad-preview/#findComment-12154 Share on other sites More sharing options...
[Na...] Posted August 6, 2024 Share Posted August 6, 2024 Hello, if you want a "drawing like" look you may use the ISO 3D labels for your inspections. Nanno Link to comment https://qualityforum.zeiss.com/topic/4166-display-distance-same-as-autocad-preview/#findComment-12160 Share on other sites More sharing options...
