[Pe...] Posted August 16, 2024 Share Posted August 16, 2024 Hi collegues, please be kind to help me if you could. There are two topics: 1. question: There are two different CAD models (two step files) which should fit together. How can I align them? Can I Import them separetely, part and part1 or .... ?.... I would like to assemble both of them "virtually" and inspect how the fitting looks like, is there a cover or play or something else. I thought to create a section on the assebly and see the actual section of the mesh. 2. question: After then I would like to rotate each CAD eg. 90°, recalculate the project and see again the section what changed. Of course I would like to see all changes on the mesh and on the new stages. Thank you so much. Link to comment Share on other sites More sharing options...
[Je...] Posted August 21, 2024 Share Posted August 21, 2024 Hello Peter, 1. you can import them as 2 separate parts for example 1.1 You could use a surface distance or create sections and Continous Curve Distance 2. Use Alignment - Single Element Transformation - Set Matrix here all kind of optios to align an element (=CAD) are available. Best regards, Jens Braun Link to comment Share on other sites More sharing options...
