[Em...] Posted August 21 Share Posted August 21 Hi, I’m really not familiar with scripting and tried different AIs without success so I need your help! I have created “multisection parallel” on a 3D-scanned round bar. For each created section, I want to create a fitting circle as “maximum enscribed element” to be analyzed further later on. I have about 500 sections so it’s let say tedious to manually create each circle. Or do you have another idea to analyze the cross-sectional area along a round bar? Many thanks! /Emil Link to comment Share on other sites More sharing options...
[Je...] Posted August 22 Share Posted August 22 Hey Emil, it's totally understandable that you are looking for a smart way through this 500-section-monster. For such tasks I recommend you the 'User-defined Inspection Principle'. You can see this as a blue-print for an element construction sequence which is defined by you and which can be applied to any amount of elements by just on click. See it as a tree which grows from one specific element type (eg a section) and builds all required follow-up elements based on that first element. For more details feel free to have a read: ZEISS Quality Tech Guide - Define User-Defined Inspection Principle Hope this helps Link to comment Share on other sites More sharing options...
[Be...] Posted August 22 Share Posted August 22 One additional hint: Together with the Cluster-Functionality you can "multiply" one element to different locations (translated or rotated). May be this makes also sense for you?! Link to comment Share on other sites More sharing options...
[Em...] Posted August 22 Author Share Posted August 22 Yes this is only 1 out of 16 scans so it’s just a part of the monster! Many thanks to both of you! I’ll try tomorrow when I have time. I’ll check tomorrow but do you know if your suggestion also works in GOM Inspect suite 2020 which is the latest license we have bought. Link to comment Share on other sites More sharing options...
[Be...] Posted August 23 Share Posted August 23 These functionality should also be available for SW2020. Some improvements were done in the cluster functionality for newer versions, but I guess the base functionality could already be sufficient for you. Link to comment Share on other sites More sharing options...
[Em...] Posted August 23 Author Share Posted August 23 It worked beautifully once I understood it, thanks! I’ll definitely use this function more in the future. Link to comment Share on other sites More sharing options...
[Da...] Posted September 3 Share Posted September 3 Please sign in to view this username. , I would like to know more about your inspection tasks. When are you free for an online call? Thanks! Link to comment Share on other sites More sharing options...
[Em...] Posted September 18 Author Share Posted September 18 Please sign in to view this username. , you can contact me at emil.strandh@swerim.se Link to comment Share on other sites More sharing options...
