GOM Inspect vs Windows 11
Good evening,
According to several topic and specifically this anwser :
The execution of any older version than Gom inspect 2022 will be block starting from windows 11.
Can you confirm that ?
What are our option if we MUST use older version and are forced by the SSI teams to ubdate windows ?
Best Regards,
Maxime S
Hello,
we cannot confirm that:
It's still possible to work with older versions then GOM Inspect 2022 on Windows 11. But problems can happen, which we are not aware of, because we do not support older versions then GOM Inspect 2022 with Tests on Windows 11.
In case you are facing a problem with the use of Win11, please contact our Support.
Greetings
Anne Schnabel
Edited
  • 4 months later...
