[Ch...] Posted September 17, 2024 Share Posted September 17, 2024 Hi, I am working in Zeiss Inspect. I am new to Python scripting in the Add-ons. I am trying to generate a report which lists details about each stage range in my project. I am able to export the name of each stage range as well as the index of the corresponding first and final stages. But I am struggling to get the time information for these stages. I did not find out how to access that data. I used the Script Object window to try to find out where to access that data but I wasn't successful. The only way I manage to get some time information is by using "relative time". But this does not seem to be what I am looking for. This seems to output the time information of the currently selected frame in the main user interface. Thanks for any help you might be able to offer 🙂 Chris Link to comment Share on other sites More sharing options...
[Ch...] Posted September 17, 2024 Author Share Posted September 17, 2024 Solved. Working within Visual Studio Code helped me to identify the attribute I was looking for: gom.app.project.stages[stage_index].time_stamp Link to comment Share on other sites More sharing options...
[Er...] Posted November 4, 2024 Share Posted November 4, 2024 I am currently facing a similar problem. I export the recording time with the following code example. Unfortunately, the output is only accurate to the minute. Is it also possible to export seconds and milliseconds in the time format? import gom current_component = gom.app.project.actual_elements.filter('type','surface_component')[0] time = current_component.get('stage.absolute_time_stamp') print(time) >>> 21.01.2021 11:42 Furthermore, the command in Christophe's post only provides the relative timestamp. Is it possible to change it to the absolute time? gom.app.project.stages[stage_index].time_stamp Link to comment Share on other sites More sharing options...
