Backprojection in Python script
Hey there,
Is there is a Python command with which you can automatically project the lines back onto the scanned component? I am using the sofrware Zeiss Inspect Optical 3D and the Scanner AtosQ.
With kind regards,
Jure Baloh
Hi,
You can try to record the manual workflow (see ZEISS Quality Tech Guide) in the script editor. If it is possible to record the command, you can generalize it and use it in scripting. Otherwise the command is not accessible from Python.
Best regards,
Matthias Prinke
  • 9 months later...
Hello,
unfortunately the recording of this command does not work. Are there other ways to integrate this command into the python code?
With kind regards,
Jure Baloh
