[Ju...] Posted September 25, 2024 Share Posted September 25, 2024 (edited) Hey there, Is there is a Python command with which you can automatically project the lines back onto the scanned component? I am using the sofrware Zeiss Inspect Optical 3D and the Scanner AtosQ. With kind regards, Jure Baloh Edited September 25, 2024 Link to comment https://qualityforum.zeiss.com/topic/4300-backprojection-in-python-script/ Share on other sites More sharing options...
[Ma...] Posted September 27, 2024 Share Posted September 27, 2024 (edited) Hi, You can try to record the manual workflow (see ZEISS Quality Tech Guide) in the script editor. If it is possible to record the command, you can generalize it and use it in scripting. Otherwise the command is not accessible from Python. Best regards, Matthias Prinke Edited September 27, 2024 Link to comment https://qualityforum.zeiss.com/topic/4300-backprojection-in-python-script/#findComment-12676 Share on other sites More sharing options...
[Ju...] Posted July 14, 2025 Author Share Posted July 14, 2025 Hello, unfortunately the recording of this command does not work. Are there other ways to integrate this command into the python code? With kind regards, Jure Baloh Link to comment https://qualityforum.zeiss.com/topic/4300-backprojection-in-python-script/#findComment-135151 Share on other sites More sharing options...
[Br...] Posted August 5, 2025 Share Posted August 5, 2025 Hello ! The command is : gom.interactive.sys.project_elements_on_measuring_object (elements=[gom.app.project.actual_elements['Section 1'] To stop the projection you have to press Escap keyboard key. If you want to stop the projection through a dialog button you have to emulate the escap key strike on this button i.e: press_key(0x1B) with the class : class KeyboardInputSimulator: """ Cette classe permet de simuler des entrées clavier en utilisant l'API Windows via ctypes. Méthodes : ----------- - __init__() : Initialise une instance de la classe et configure la fonction SendInput de l'API Windows. - press_key(hex_key_code) : Args : hex_key_code (int) : Code hexadécimal de la touche à simuler. Returns : """ def __init__(self): self.send_input = ctypes.windll.user32.SendInput def press_key(self, hex_key_code): """ Simule l'appui sur une touche du clavier en utilisant le code hexadécimal de la touche. Args: hex_key_code (int): Code hexadécimal de la touche à simuler. Returns: None """ extra = ctypes.c_ulong(0) ki = KeyBdInput(hex_key_code, 0, 0, 0, ctypes.pointer(extra)) ii = InputUnion() ii.ki = ki # Affectation correcte x = Input(ctypes.c_ulong(1), ii) # Création correcte de l'objet Input self.send_input(1, ctypes.pointer(x), ctypes.sizeof(x)) 1 Link to comment https://qualityforum.zeiss.com/topic/4300-backprojection-in-python-script/#findComment-136271 Share on other sites More sharing options...
[Ju...] Posted July 13 Author Share Posted July 13 Please sign in to view this quote. Hey Brice, can you also give me an example of the Dialogcode please? Link to comment https://qualityforum.zeiss.com/topic/4300-backprojection-in-python-script/#findComment-152783 Share on other sites More sharing options...
