Inspection Element export
I am working on scripting for export csv file, my script is like below,
elem = gom.ElementSelection ([gom.app.project.inspection['F1895734E212BR_Z-TXH.X'], gom.app.project.inspection['F1895734E212DL_Z-TXH.Y'], gom.app.project.inspection['F1895734E048BL_Z-TXH.Y'], gom.app.project.inspection['F1895734E212CR_Z-TXH.X'],
gom.script.table.export_table_contents (
    additional_information='\nProject: Model - S\nPart Name: $format (user_part, "", show_unit=false, date_format=\'M/d/yyyy\')$\nPart Number: $format (user_part_nr, "", show_unit=false, date_format=\'M/d/yyyy\')$\nSample Number: $format (user_serial_nr, "", show_unit=false, date_format=\'M/d/yyyy\')$\nInspector: $format (user_inspector, "", show_unit=false, date_format=\'M/d/yyyy\')$\nDate: $format (user_date, "", show_unit=false, date_format=\'M/d/yyyy\')$',
    cell_separator=',',
    codec='iso 8859-1',
    decimal_separator='.',
    elements= elem,
    file= filenameA,
    header_export=True,
    line_feed='\n',
    sort_column=0,
    sort_order='ascending',
    template_name='Overview',
    text_quoting='',
    write_one_line_per_element=False)
How do i get "elem = gom.ElementSelection ([gom.app.project.inspection......" to get all inspection points without specified by each point's name?
Thanks a lot.
Edited
Hi,
You can use the function gom.ElementSelection() as described in Selecting elements in scripts — Add-On Documentation (zeissiqs.github.io).
For example:
elements=gom.ElementSelection (
    {'category': [
        'key', 'elements', 'part', gom.app.project.parts['Part'], 'explorer_category', 'inspection',
        'object_family', 'geometrical_element', 'type', 'inspection_point'
Best regards,
Matthias Prinke
