how to check if sensor is initialized
Hi Aaron
There is a boolean variable for this. You can access it via:
gom.app.sys_is_sensor_initialized
To find other variables, you can use the command "rightclick>Insert>Element value.. (F2)" in the script-editor.
Hope this helps.
