Add-On Resources
  • 3 weeks later...
Hi,
import_gom_inspection_exchange needs a regular file name, neither a file handle nor a resource object works instead.
You can use the following workaround:
import gom
import tempfile
import os
# Copy the resource to a regular (temporary) file
with gom.Resource('Points.gxml').open() as gxml_file, tempfile.NamedTemporaryFile(delete=False) as temp_file:
	data = gxml_file.read()
	temp_file.write(data)
# Import from temporary file
gom.script.sys.import_gom_inspection_exchange (files = [temp_file.name], import_mode = 'clipboard')
# Remove temporary file
try:
	os.remove(temp_file.name)
except:
	pass
Best regards,
Matthias
  • 3 weeks later...
Thank you Matthias, that worked perfectly!!
I initially tried to reference https://zeissiqs.github.io/zeiss-inspect-addon-api/2023/python_api/python_api.html#example
load it directly from the add-on filepath, but that only worked when the add-on was in edit mode.
upon further reading it looks like the .addon is just a zip file, so I used zipfile to unzip it into an "extracted" folder.
(tempfile and unzipping was giving me problems for some reason)
Both methods seem to work, thank you for your help!!
# -*- coding: utf-8 -*-
import gom
import os
import tempfile
import zipfile
Method = 1
#Method = 2
if Method == 1:
	with gom.Resource('Large_Fixture_CSYs.zelements').open() as zelements, tempfile.NamedTemporaryFile(delete=False, mode = 'wb') as temp_file:
		data = zelements.read()
	gom.script.sys.import_project(
	file=temp_file.name,
	import_mode='clipboard')
#	gom.script.sys.import_gom_inspection_exchange (files = [temp_file.name], import_mode = 'clipboard')
	try:
	except:
		pass
if Method == 2:
	# Resource paths
	Large_Fixture = 'scripts/Resources/Large_Fixture_CSYs.zelements'  # Full relative path inside the .addon archive
	# Get the current add-on
	current_addon = gom.api.addons.get_current_addon()
	# Check if the add-on is in edit mode
	if current_addon.is_edited():
		# If the add-on is in edit mode, combine the resource path with the add-on's file path
		Resource_fpath = os.path.normpath(os.path.join(current_addon.get_file(), Large_Fixture))
		print(f"Add-on is in Edit Mode. Using:\n{Resource_fpath}")
	else:
		# If the add-on is not in edit mode, extract the specific file from the .addon archive
		addon_zip_path = os.path.normpath(os.path.join(gom.app.public_addon_directory, f"{current_addon.get_name()}.addon"))
		print(f"Add-on is NOT in Edit Mode. Extracting .addon file:\n{addon_zip_path}")
		# Define the extraction directory (same as .addon file location, in a subfolder named 'Extracted')
		extraction_dir = os.path.join(os.path.dirname(addon_zip_path), "Extracted")
		os.makedirs(extraction_dir, exist_ok=True)
		# Extract only the specific file
		with zipfile.ZipFile(addon_zip_path, 'r') as addon_zip:
			if Large_Fixture in addon_zip.namelist():
				# Extract the file
				extracted_path = os.path.join(extraction_dir, os.path.basename(Large_Fixture))
				with open(extracted_path, 'wb') as extracted_file:
					extracted_file.write(addon_zip.read(Large_Fixture))
				print(f"Specific file extracted to:\n{extracted_path}")
				Resource_fpath = extracted_path
			else:
				raise FileNotFoundError(f"The file '{Large_Fixture}' does not exist in the .addon archive.")
	# Import the resource from the resolved path
		file=Resource_fpath,
