[Iv...] Posted 14 hours ago Share Posted 14 hours ago Please assist ASAP, Thank You. Link to comment Share on other sites More sharing options...
[Be...] Posted 12 hours ago Share Posted 12 hours ago Hi, for questions regarding your particular hardware you should always contact directly your local ZEISS partner. The Forum is usually not the right tool for answering questions like this. Regards Link to comment Share on other sites More sharing options...
[Ja...] Posted 3 hours ago Share Posted 3 hours ago From memory the hardware manual for the scanbox does give you instructions what to do. Its replacing 4x D batteries in the robot. These batteries are needed to keep the encoders active ...so as it says keep the Scanbox ON until you sort out the battery swap. Nothing will go wrong unless you turn the power off, as then you may end up with a non working system/ needing engineer to reset encoders. Link to comment Share on other sites More sharing options...
