[1c...] Posted November 5, 2024 Share Posted November 5, 2024 Hello everyone. I'm having trouble to get excel report from Calypso. I believe I have set everything correctly (macros are enabled). I can see the excel report on the screen (after the run) for about 3 sec. Then it is closed and not saved. I work with Calypso 2023 (ServicePack 4). Any idea what could be the problem? Link to comment Share on other sites More sharing options...
[DW...] Posted November 8, 2024 Share Posted November 8, 2024 Do you have anything in this folder? "C:\Users\Public\Documents\Zeiss\CALYPSO\workarea\results" Link to comment Share on other sites More sharing options...
[1c...] Posted November 11, 2024 Share Posted November 11, 2024 Yes, txt files are stored there. Calypso has write access to this directory. I tried several things (e.g. edit the name of the program, the name of the characteristic, in case it contains unsupported characters). Still without success. Link to comment Share on other sites More sharing options...
[Ja...] Posted November 11, 2024 Share Posted November 11, 2024 Do you have a default path for results set under extras, settings, environment, paths? That should be where they are going. Link to comment Share on other sites More sharing options...
