[Si...] Posted November 5, 2024 Share Posted November 5, 2024 Hi, Is there any way to get the X,Y position of a curve on the muliple report. Link to comment Share on other sites More sharing options...
[Ma...] Posted November 5, 2024 Share Posted November 5, 2024 If you need to have some kind of "central" point of curve you can use alignment from many curves make alignment from many curves select your curve make theoretical point - ideally in center of a curve set feature alignment for that point as alignment from step 1 and 2 Now you will have that point moved by bestfit deviation. If you need to report it's XYZ then you need to recall that theoretical into base alignment ( using recall feature and using base alignment for features alignment ) Link to comment Share on other sites More sharing options...
