Measurement Quality - Low
Hi,
I created a scanning template and been using for sometimes and the measurement quality is always 'High". Sometimes there are waypoint that turn into "low" quality, and what I did was rescanning that particular waypoint again and it change to "high" maybe due to some sensor movement etc.
Is it a problem when the measurement quality turns to "low"? I still can polyganize it. But will the "low" measurement quality affects my final scan significantly? How to improve this measurement quality and transformation quality?
Thank you!
https://qualityforum.zeiss.com/topic/4424-measurement-quality-low/
  • 5 months later...
Hi Sarah,
the low quality shots can be due to sensor movement. the right and left camera not see the same Pixel values with the target repositioning  the sesor and rescanning will probably fix those shots.
as for the over all a few low quality shot will not hurt the project but when you get to a higher amount then yes they will if the low quality shot are not need and you have captured the data in other shots i normally try and remove any low quality or try and re-shoot them. you can also give this tech guide article a look over some of the information  may help.  https://techguide.zeiss.com/en/zeiss-inspect-2025/article/how_to_improve_the_measuring_accuracy.html
