Found a little bug with Clipping Pane
I use Clipping Plane quite a bit, today I had it opened and set to an Alignment, Alignment1 Ref #1007.
Somehow in Clipping Plane mode, it thinks the name is "Alignment1 Rf #1007". (I definitely did not rename the alignment).
Now I can't use Clipping Pane because all it does is generate an error. I have terminated Calypso and the error persists.
Rebooted my PC and restarted Calypso, same error.
I found a fix after reading the Error Report:
I am posting this for our knowledge, if you run into this problem look into the Error Report and find the offending Alignment name.
Create an Alignment with that exact name.
After, you should be able to open Clipping Plane and deselect the offending Alignment.
