Can you export data points from a cross section into an excel doc?
As the headline says. Is there a way to export the data in a cross section from an object into, for example, Excel?
Or if that is not possible, how du you go about comparing the cross section on an actual object with the same cross section on a nominal object. (I only have basic skills here...) I think I can figure out how to align the nominal with the actual object, and have already made the cross section I want on the actual.
Hi,
may be you should have a look into the functionality 'Inspection section' in ZEISS Inspect?! This gives you colored deviation section. You can add some pickers to derive the concrete values. May be this video is helpful:
  • 2 weeks later...
