[Ra...] Posted September 23, 2021 Share Posted September 23, 2021 We recently had our Scanbox 5120 cell re-located and re-calibrated by our local GOM partner, Capture3D. We were provided with new project templates for each measuring volume that included the latest cell calibration information. We were told that we would need to update any existing project templates with this new VMR cell calibration by dragging our project into the new template and then saving the result as the updated template. However, when we do this, our existing measurement series data gets deleted, which results in extensive re-programming time. Is there another method to update the cell calibration information in existing project templates? Thanks, Ray Romesburg Link to comment Share on other sites More sharing options...
[Ma...] Posted September 27, 2021 Share Posted September 27, 2021 Hello, Yes, exchanging the VMR is the correct way how to adapt existing project templates to a new cell calibration. The software adapts the existing programs to the new geometric situation. You can use Scripting - Tools - UpdateProjectTemplates - Start... to do this automatically for all your templates. What do you mean by "existing measurement series data gets deleted"? This should not happen. Automatic calculated scan masks and automatic exposure times are reset and will be recalculated on the next measurement. (We recommend to save the template again after the measurement to fixate the new masks and exposure times in this case.) If the geometric change is somewhat bigger, some (or all) of the measurements will be slightly relocated in the VMR with the consequence that the robot path is changed and needs re-validation. You can prevent this possible relocation by setting "VMR reference coordinates" to "Positions in robot axis coordinates" in the (expert) parameters of the nominal measurement series before exchanging the VMR if the project is a "parts project". Measuring data (i.e. result data, i.e. measurement meshes) is normally not included in project templates. Regards Matthias Aalto Link to comment Share on other sites More sharing options...
[Ra...] Posted September 30, 2021 Author Share Posted September 30, 2021 Thank you for your response, Matthias. Apparently, the templates that Capture3D left with us were not set up correctly. We were told to drag our existing project into the templates with the new VMR. This only brought in the CAD, Mesh, and inspection plan. What we learned later on was that we should drag their template into the existing project and select "Replace VMR"; however, the way Capture3D configured the file would not show us that option. I believe our issue has been resolved, but it would be helpful if Capture3D would provide better support and instructions following their service visits. Best regards, Ray Romesburg Link to comment Share on other sites More sharing options...
[Ma...] Posted October 4, 2021 Share Posted October 4, 2021 Ah, thank you for the information. Some side note: In current software versions, the option "Replace VMR" is only shown if importing a gelements file containing a VMR, not if importing a whole project (atos or ginspect file). Omitting this import option helps reducing the number of import options for whole projects but apparently may lead to confusion. However, a workaround is simple: Select the VMR in the project to import and choose "File - Export - Export selected elements" and import the gelements instead. Nevertheless, we should re-think this and avoid the confusion. Regards Matthias Aalto Link to comment Share on other sites More sharing options...
[Ma...] Posted December 1, 2025 Share Posted December 1, 2025 Hello, I seem to be having a similar issue. We recently had Zeiss move our Scanbox 5120 and leave a new project template, but when I drag and drop the updated VMR into a previous project - it gives me three options: Add measurement series, replace measurement series, and replace actual measurements only. I will click the replace option and it tells me "Error MCADCmd-0049: Cannot import the project data. The project contains no importable data." Do I need to contact Zeiss or should I start reprogramming previous measurement plans? Zeiss Inspect 2023 w/ Airfoil. Link to comment Share on other sites More sharing options...
[Ra...] Posted December 2, 2025 Author Share Posted December 2, 2025 Hi Matthew, As Matthias mentioned above, you need to open the project template that Zeiss left with you after your cell calibration, then select the VMR in the Explorer under "Measuring Environment" (ours is called "ATOS Scanbox 5120"). With your VMR selected, go to File|Export|Elements|Selected Elements Only and save the file (as a *.zelements file) wherever you'd like to keep your VMR back-up. Then, when you create a new template, you can use the File|Import function and then select the *.zelements file that you just saved. It should then import the VMR under the "Measuring Environment". Hope this helps! Ray 1 Link to comment Share on other sites More sharing options...
[Ma...] Posted December 2, 2025 Share Posted December 2, 2025 Ray, Thank you for the reply. I realize I made a rookie mistake, I didn't have the VMR selected when I exported elements. That did the trick, I appreciate it. 1 Link to comment Share on other sites More sharing options...
