Results comparison
I have two 543 O-inspects running the same program, same master part. Results attached. The greatest difference from all the dimensions (that I'm concerned with) is 0.0003" All of the dimensions shown are measured with the Dotscan except for 221 (4x).
Is a difference of 0.0003 large enough to be concerned?
150_f7332a049f221fee74347aa194d9b4aa.xlsx
https://qualityforum.zeiss.com/topic/4472-results-comparison/
In this particular situation, I am concerned with the fact that two different machines running the exact same
program and the exact same part are getting 0.0003" difference in two of the dimensions measured. I need to
know, 1) is this too much? (I believe it is) and 2) what is causing the difference?
https://qualityforum.zeiss.com/topic/4472-results-comparison/#findComment-13354
That difference is 0,00762mm - so this can be dust, temperature, probing head, calibration. It depends on type of part ( grinded, milled, any surface finish )
Strategy can effect too - scan would point to probe head/tip
Is deviation on specific axis so it can be confirmed with cal. ring?
https://qualityforum.zeiss.com/topic/4472-results-comparison/#findComment-13356
Parts are thoroughly cleaned before measurement. Measurement was done directly after each machine had
all its sensors qualified. Part is a centerless ground SS cylinder. The dimension in question 3d curves measured
with the White-light (DotScan). Then a contour in best fit construction from those measured curves.
https://qualityforum.zeiss.com/topic/4472-results-comparison/#findComment-13358
