[Ri...] Posted November 1, 2024 Share Posted November 1, 2024 I have a special probe that is about 225mm in the -Y axis on an XTR sensor. I parked this in the lower right of the rack. I chose this location, so it won't interfere with parts on fixtures. What I want the probe to do, and can't seem to get it to do it, is get picked up and move in the following axis. 1. Y axis to clear the probe rack if the probe will articulate to the +Y axis. 2. Z axis clear up about 400mm. 3. Y axis negative movement prior to any probe articulation. It seems that retrieving the probe it always moves Y, X then Z. I want Y, Z then X. Any help is appreciated. Link to comment https://qualityforum.zeiss.com/topic/4488-probe-rack-approach-parameters/ Share on other sites More sharing options...
[Ri...] Posted November 1, 2024 Share Posted November 1, 2024 You should be able to achieve this with the Define Path option for the Before Change and After Change inside of the Approach Parameters. Link to comment https://qualityforum.zeiss.com/topic/4488-probe-rack-approach-parameters/#findComment-13458 Share on other sites More sharing options...
[Ri...] Posted November 4, 2024 Author Share Posted November 4, 2024 Please sign in to view this quote. I have never used this, guess I will read up and try this approach. Thanks. Link to comment https://qualityforum.zeiss.com/topic/4488-probe-rack-approach-parameters/#findComment-13460 Share on other sites More sharing options...
