Datum shift
We are using Calypso 2021 and have multiple positions on an assembly allowing datum shift for datum B, an OD. I am under the impression that in this version you can apply datum shift but the software does not account for other positions using that same datum. Am I correct? If so, has this been corrected, improved in later versions?
I assume your concern is simultaneous requirement with same DRF on other features. I would try grouping ALL the same DRF requirements into a pattern, and see what you get. You can grab the Datum shift values from each one and report in Result Element.
