[Ll...] Posted October 24, 2024 Share Posted October 24, 2024 We are using Calypso 2021 and have multiple positions on an assembly allowing datum shift for datum B, an OD. I am under the impression that in this version you can apply datum shift but the software does not account for other positions using that same datum. Am I correct? If so, has this been corrected, improved in later versions? Link to comment https://qualityforum.zeiss.com/topic/4542-datum-shift/ Share on other sites More sharing options...
[Ma...] Posted October 24, 2024 Share Posted October 24, 2024 You mean MMB? Link to comment https://qualityforum.zeiss.com/topic/4542-datum-shift/#findComment-13766 Share on other sites More sharing options...
[Ll...] Posted October 25, 2024 Author Share Posted October 25, 2024 Yes. MMB is datum shift as I understand it. Am I incorrect to use that term? Link to comment https://qualityforum.zeiss.com/topic/4542-datum-shift/#findComment-13768 Share on other sites More sharing options...
[Jo...] Posted October 25, 2024 Share Posted October 25, 2024 Please sign in to view this quote. I assume your concern is simultaneous requirement with same DRF on other features. I would try grouping ALL the same DRF requirements into a pattern, and see what you get. You can grab the Datum shift values from each one and report in Result Element. Link to comment https://qualityforum.zeiss.com/topic/4542-datum-shift/#findComment-13770 Share on other sites More sharing options...
