Change Probing Vector off the CAD model
Hello,
I am ran into an issue on a part where I am trying to probe a rounded circular edge in Zeiss Calypso 2022. In order to do this, I created a section view via CAD-entity, and created a circle to find the radius. That in theory worked fine, but when I went to run the part, it tried measuring this feature from inside the part, resulting in a crash. (It tried to measure it as an inside radius when it is an outside radius). I thought there was a way of changing the probing vector to correct this, but could not find it. Any help here?
P.S. I know I can measure it manually, but going forward, it would be simpler to set up via the CAD.
Thanks! 6609_744c9d9f22439c19831eba0d1d7ed82e.png 6609_57ef1f4785943a5b4865dc88c8c875d0.png
https://qualityforum.zeiss.com/topic/4570-change-probing-vector-off-the-cad-model/
