[Ed...] Posted October 16, 2024 Share Posted October 16, 2024 Hi, I`m measuring circular pitch on part with "Curvic" I need to show our customer Fp with eccentric correction, like with GearPro. Is it possible to do in Calypso? (1.png) Second question is how to export measuring points from this pitch measurement? I found this in Result to file, but how this work, where can I find the exported results (3.png) What I`m missing for? Thanks 🙂 Link to comment Share on other sites More sharing options...
[Ma...] Posted October 16, 2024 Share Posted October 16, 2024 I'm not sure about removing eccentricity without GearPro but for exporting points try this. In Measurement Plan Editor select Geometry and Export Points. If you click on selected features you can select the feature and use the drop down to turn it on for exporting. Then go into Name definitions for output files and find Export Points in the dropdown and set the directory. Link to comment Share on other sites More sharing options...
[Ed...] Posted October 17, 2024 Author Share Posted October 17, 2024 Hi, Tryed this before, but something went wrong. When I press "File Ending" I have this error I added +".txt" manually and than I have just a folder without any data Can`t understand what I`m missing 🙁 Link to comment Share on other sites More sharing options...
[Ma...] Posted October 17, 2024 Share Posted October 17, 2024 You have to add the +".txt" at the end of the path. Link to comment Share on other sites More sharing options...
[Ma...] Posted October 17, 2024 Share Posted October 17, 2024 Oops sorry just saw that you tried that. You turned on exporting points for the feature as in the first screenshot? Link to comment Share on other sites More sharing options...
[Ma...] Posted October 17, 2024 Share Posted October 17, 2024 Link to comment Share on other sites More sharing options...
[Ed...] Posted October 18, 2024 Author Share Posted October 18, 2024 Hi again, To be sure I turned on for all features, added +".txt" and it created folder, but the folder is empty. This is what our customer text me: What I need is basically just the results for Fp or fp in a machine-readable format like .txt or .csv. The Zeiss should have an automated export function. Link to comment Share on other sites More sharing options...
[Je...] Posted October 18, 2024 Share Posted October 18, 2024 Before the point export works, you have to do it manualy one time. After you ran your plan, right click on one feature -> export point -> set the settings you need -> export. After that your automatic export should work Link to comment Share on other sites More sharing options...
[na...] Posted February 4 Share Posted February 4 Please sign in to view this quote. Jens, it's been a while since I had to use export points, but as I recall there should be characteristic to the feature whose points are exported. Link to comment Share on other sites More sharing options...
