[hu...] Posted October 16, 2024 Share Posted October 16, 2024 Hello. Can someone please tell me what the difference is between having it on and off in the System Settings Thank You. Link to comment Share on other sites More sharing options...
[Ma...] Posted October 16, 2024 Share Posted October 16, 2024 When using a cylinder as a datum you must take care that the cylinder form is good. ISO 5459 will use the centerline of the cylinder with no respect for the form. However, you need to increase your section scans. Do not use just two sections, if possible, use 3 or 5 scans based on the bore depth calculation in the Cookbook. Link to comment Share on other sites More sharing options...
[Ch...] Posted October 16, 2024 Share Posted October 16, 2024 Here are a few documents that may help answer your question: CALYPSO: ISO 5459 - https://portal.zeiss.com/knowledge-base?id=457159 CALYPSO Operating Instructions: Link to comment Share on other sites More sharing options...
