Intersection Between Radii / Circles
Hi,
My print calls for an intersection point between two connected radii (the geometry is similar to an "S" shape). How can I create this intersection point in Calypso?
Thanks
Hi Lukas,
If I understood you correctly, you can create a 3D-line between the two centers of the circular segments. You can then intersect this 3D-line with one of the circular segments.
