Radius on top of a cone
I have this super simple part and measurement, but as it is often the case, cannot get it going because of the base alignment.
All I am interested is a R 0.01 radius measurement on the top of a cone on a 0.250 rod. I thought I could use the top for space rotation with Z+, no planar, the rod diameter for X and Y, and the top again for Z.
I plan to use a 0.5 mm stylus in the right horizontal (#3) position.
Can someone tell me why it isn't accepted by Calypso? And what would work? I tried many variations... to no avail.
Attached are some screenshots
Thanks for your thoughts
CONE 2.JPGFetching info... CONE 1.JPGFetching info...
The Spatial must be a feature capable of controlling 2 axes of rotation. Since a circle is a 2d feature, it cannot.
How about a cylinder from the OD, and maybe a point on top for Z
Or, maybe use a cone for the Spatial and X/Y origin and point for Z. That might help if the sphere is not in-line with the cylinder.
Well...I thought I had it, but it doesn't seem to find the part. It wants to go to the right and approach from there, but naturally runs into obstacles. My clearance plan is Z+, but still goes to the right.
Any idea what I do wrong?
here is a video of the move:
https://share.icloud.com/photos/09e_UFO ... eR_MYrZ2OA
Use the cylinder OD as XY zero and spatial. Measure 2 equally spaced lines up
opposite sides of the cone. Intersect them. Use that intersection (Point) as Z zero
in a secondary alignment (XYZ). Assign that alignment to the tip sphere/radius.
Now the probe should hit the target spot on.
I would use a straight down (Z-) stylus to measure the tip, You'll be able to measure a larger radius. I'd measure it as a sphere using probing points as opposed to scanning it. I'd also suggest and constraining XY&Z
That sounds good, but the CMM cannot "find" the part, to me that is the bigger issue. Once the probe goes directly to the feature, I can change or manipulate the strategies, but it has to recognize the part location first, and I don't know why it doesn't
By the way, I do use the 3mm down probe for the point on the top, and planned to use a .5 mm #3 right probe to scan the radius but I can try the 3mm down probe to touch off the radius, once it finds it and "goes" there
Are sure you have the correct probe assigned to the point?
The screen shot shows the 3mm down probe assigned and that isn't a 3mm probe.
Go to the measurement plan editor and choose "Stylus" and take a screen shot of the probes assigned with the clearance group assigned beside it, that may help show the problem.
Sorry, I didn't scroll far enough. Everything looks good here.
I would go to Resources > Utilities > Set Base Alignment to Zero.
Then run a manual alignment.
