Rondcom
On a straightness measurement: Is there a way I can add a pre/post travel for the measurement? (e.g. extend past the measurement start and end location .020in)
I see the options but can’t modify. And what are the ‘Reserved drive available’ & ‘Reserved drive return’ options? When I select them the only value that is available is .1575.
On a roundness measurement: Does the circle path measure 360°? Not sure if this is adjustable or set, on Calypso I always change the 360 to 380 and was wondering about the Rondcom.
