90* probe
Howdy, I have to build a 90* probe and I've noticed the threads aren't timed correctly, How do you guys build a 90 degree probe to be parallel to x/y axis. My only thought was to get some .005" shim washers and time it that way. VAST XTR probe
Thanks!
-Max
That works. If this is an XT adapter plate, you can loosen the 3 screws on the backside and rotate them the assembly as needed.
F1 Calypso help: Fine angle adjustment
The ZSH-70-R-24 plate can be loaded in maximum 24 different positions into the probe. This results in the minimum step width of 15°. Any positions in between you may require for certain tasks can be realized by rotating the cube on the lower side.
To do so, loosen the four screws on the lower side so that the cube can be rotated. Then tighten the screws again.
