[Ro...] Posted September 25, 2024 Share Posted September 25, 2024 Hello, I need, easy help considering my crowd, with creating a distance program. It has just two plane features, sitting vertical from each other (II). The program needs to show the distance between the two features. My question: which characteristic is best to use when just finding the distance between two features, in this case planes? Simple distance, caliper distance, point distance etc. The CMM is a Contura. Link to comment Share on other sites More sharing options...
[Ma...] Posted September 25, 2024 Share Posted September 25, 2024 I would use Cartesian distance, since it's not dependant on alignment. But sometimes you would need to use two Cartesian distances since they are not prefectly parallel. 1. for plane1 to plane2 2. for plane2 to plane1 Using Caliper distance you can get Min/Max/Mid distance value, but it's alignment dependant. Link to comment Share on other sites More sharing options...
[Ro...] Posted September 25, 2024 Author Share Posted September 25, 2024 Thank you, Martin. I will try the two cartesian distance. Appreciate your input. Link to comment Share on other sites More sharing options...
[4e...] Posted October 4, 2024 Share Posted October 4, 2024 I recently started using the Constructions 'Minimum Coordinate' and 'Maximum Coordinate'. Set up these pointing to one of the planes, perhaps the smaller or non-datum one. Then request Cartesian Distances with the Min or Max Coordinate called out first then the opposite plane. The specifications for one of our customers direct us to do it this way. Seems to yield sensible results. As much as possible verify with alternate means, eg Gage Blocks. It doesn't take much time, and it will put you on much more solid ground if measurements are ever questioned. Link to comment Share on other sites More sharing options...
