[Fu...] Posted February 13, 2020 Share Posted February 13, 2020 I would know how I can create and register a new stylus, that there isn't in SSC database, and use it other times in future. Is it possible? Link to comment Share on other sites More sharing options...
[No...] Posted February 14, 2020 Share Posted February 14, 2020 You mean a new (non-standard) stylus element in the SSC editor? You can't add anything to the database yourself, because the formats of the geometry data as well as the database are proprietary. I think Zeiss does add customer-specific elements on request, but of course this is not for free. You can however construct your own stylus from generic elements (hint: generic spheres can be defined as a ruby tip) and save it for later use. It can be imported and connected to a joint like any other element. Link to comment Share on other sites More sharing options...
[Fu...] Posted February 14, 2020 Author Share Posted February 14, 2020 Hi Norbert, I mean a standard stylus (on sale in the web shop), but not present in the SSC db. Link to comment Share on other sites More sharing options...
[Fu...] Posted February 14, 2020 Author Share Posted February 14, 2020 I've the last version of SSC: 1.7.6991. Link to comment Share on other sites More sharing options...
[No...] Posted February 14, 2020 Share Posted February 14, 2020 Well, there's nothing you can do about that. Except discuss with Zeiss why standard elements are missing from the db. They may be able to provide a newer version of the db. Link to comment Share on other sites More sharing options...
[Fu...] Posted February 14, 2020 Author Share Posted February 14, 2020 Ok, thank you very much.... 😉 Link to comment Share on other sites More sharing options...
[HU...] Posted June 27, 2023 Share Posted June 27, 2023 After Import SSC file. this Styli's look like wrong location with the quill. Can you one help me fix it? thank you very much and I appreciate!!!Capture.JPG Link to comment Share on other sites More sharing options...
[Je...] Posted June 28, 2023 Share Posted June 28, 2023 Everything you need should be here; viewtopic.php?t=11400 Link to comment Share on other sites More sharing options...
[HU...] Posted July 13, 2023 Share Posted July 13, 2023 GREAT !!! THANK YOU VERY MUCH Jeff Penrod ! 😎 Link to comment Share on other sites More sharing options...
[Br...] Posted September 25, 2024 Share Posted September 25, 2024 If you have a component that is not available in the SSC, please contact Zeiss Applications Support and let us know the part number. A simple request to our colleagues in Germany will result in a file that will import into the ssc. Link to comment Share on other sites More sharing options...
[Lu...] Posted September 27, 2024 Share Posted September 27, 2024 https://portal.zeiss.com/knowledge-base ... &id=520919 Link to comment Share on other sites More sharing options...
