New point nominals are rounding.
I am selecting points on a CAD model and when I select "Define point" and click on the model everything looks good, but when I hit "OK" the yellow arrow moves and rotates. It is snapping the nominals to the closest whole numbers and axis.
I swear it used to not work like this. I assume there is a setting I am missing, I definitely do not want Calypso doing this.
Thanks in advance!
Change your "Space point mode" from "Touch point" to "Plane point" or use "Define a space point" instead of "Define points" from bottom CAD menu used to extract features from model.
Follow the link Lucas posted above. Default rounding in set to 0.10mm. i always set mine to the most minimum setting (0.0001)
This is found in Extras>settings>Measurement Nominal tab
