Will PI WEB send an AS9102 to net inspect?
Hi David. There are much more qualified people on this forum than me to answer your question, but my understanding is that you can use the "Measurement Collection Service" in Net Inspect to import from a variety of text-based files. This can be done from Calypso by exporting text files from the following types:
Characteristic info (_chr.txt)
Header info (_hdr.txt)
Feature info (_fet.txt)
You will most likely be working with the _chr.txt file for measurement data.
Another option is to export from Calypso to .QIF and then import to Net-Inspect, but I think Zeiss may have a paywall up before using .QIF
Here's some info on importing from Calypso to Net-Inspect that may be helpful:
https://net-inspect.zendesk.com/hc/en-u ... ld-mapping
